Asus B250m-k problem
joseph1968
13
Hi guys,
Problem with a simple built.
Parts:
Case- zalman z1
Cpu- pentium g4560
Mobo- asus b250m-k
1x8gb hyper ddr4 2400 mhz
Psu- seasonic S12ii 520 wats bronze.
Installed all and although not positive about front panel connectors,tried as charted.
Problem-
As i power the psu theres only back orange light on left side of mobo just above place of gpu and under ports. Its like small route orange and not just a dot lit.
I tried connecting moles fan and nothing.
Tried changing ram lane and also no ram and nothing.
Nothin on the monitor of course.
Doublechecked the psu with connecting a pin on green and black and the psu worked and molex fan worked. Went back to power the mobo and nothing. Its a new mobo but i have a feeling it may be bad.
Baught this mobo,knowing theres no need to update bios for intel 7th gen.
Need advise .
Thank you for taking the time.
Solved it guys.
The only problem was that my new build won't recognize the wireless keyboard. After trying everything ,i got a Wired one and all is gold ☺.
Thanks
Solved it guys.
Thanks
