ASUS B350-F Strix Motherboard LED issue.
bthai
15
I recently got this mobo, and when I booted it before installing an OS, all the LEDS came on and stayed and cycled through all the colors. After installing the OS and setting up everything. Now my LEDs on the mobo only come on when I first turn on the system, however, it seems like after the BIOS loads, the LEDS cutoff. Also when I installed the Aura software, the mobo is not detected at all. I have check the BIOS and the only related option I could finds in Onboard Lighting is enabled, I have tried disabling, reboot and enabled it back trying to "refresh it." I also have a Asus GPU as well but no issues at all from the GPU, LED stays on and is detected by the Aura Software. I have updated to latest biois, drivers and software versions, I am at a lost.
I have disabled and enabled this multiple times. its currently enabled and there is nothing. I have previously mentioned I have attempted this already
Sorry, i didn't know that's what you meant by "Onboard Lighting". Good luck in any case.
