Asus b85m-e Motherboard problem
NaiTreNo
7
I will try to give as many details as possible.
So today I completed my first home built PC. That being said, it doesn't really turn on...
I tried the pin test for the power supply, success, it worked
I tried to see if everything worked on the motherboard before putting it into the case ( CPU,CPU FAN, RAM. With the motherboard being connected to the power supply, as well as the CPU being connected to the power supply). I used a flat headed screw driver to start it (touched the pins with it, as I was suggested by numeral sources) and everything was working perfectly.
However! When I put everything together in the case, it didn't work so well. What happens everytime is that, the motherboard's green light appears, and when I hit the power button, my front red LED fans blinks once and then... nothing else
I am 99% sure everything is plugged in perfectly (checked SEVERAL times).
1. I tried powering it up with only 1 RAM stick... nope
2. I tried with NO RAM... nope
3. I tried without the GPU... nope
I did look at the 20+ steps for troubleshooting thing and it did not help me whatsoever.
If any of you guys know what to do... I will be forever grateful!
SPECS: (In order: Case, Motherboard, DvD-drive, RAM, HDD, Power supply, CPU)
- ASUS B85M-E DDR3 1600 LGA 1150 Motherboard
- Lg liteon dvd
- Kiingstone hyper x fury 8gb 1600Mhz
- * laptop harddisk
- Intel Core i3 4150
