Asus B85M-G power phases enough, no overclocking
cornered_fox
35
Hello,
I have an Asus B85M-G motherboard, and an i7-4790 (non-K), and after doing some research I found that the Asus B85M-G has 3 power phases (VRMs). I am using this pc for gaming, but do not plan on overclocking, will 3 power phases of the B85M-G be enough to supply the cpu with the power it needs? Are the higher power phase designs (4+1 etc) only meant for overclocking?
Thank you for any help and clarification in advance.
Thank you for such a fast reply Zerk2012. So even if I am recording gameplay with x264 (using the CPU, hitting around 70-80% cpu usage), the board can handle that without throttling the cpu? (due to heat from the power phases/not enough power from the power phases)
So what would the advantages in having more power phases be for non-overclockers?
But what if you put an 88W 4790K, will it still be okay to run it 24/7 100% with 3 phases and naked VRM?
No throttling in this scenario?
Do you have to disable turbo or you can still benefit it also with B85M series mobos?
