Hey,
I just registered to check with other people that may have this professional grade motherboard:
I've installed a 3-pin Noctua fan into this system on FAN_FRNT3, and I'm noticing that in the motherboard, no matter what fan control speed I set, it simply runs at maximum...
There are no Q-Fan or any sort of configuration in the BIOS to set it to DC Mode or PWM mode... The only choices I have are Automatic, Max Speed, or Manual. On manual, even if I force the fans to 10% utilisation, it revs at full speed. SpeedFan does not help either. My only conclusion I can think of is that the fan headers on this board only accepts PWM 4-pin fans.
Am I correct to assume that?
Thanks a lot for your help!
