Asus is working on a concept GeForce RTX 40-series graphics card that doesn't require any power cables.
Asus Demos RTX 4070 GPU With Zero Power Connectors : Read more
I think I read that this custom motherboard has some connectors at the back so maybe that is the idea, to keep things looking neat? I'm not fussed about that personally though, as long as cables don't mess with airflow too much I don't mind what they look like as I don't have them on display!The only way I can see this not being potentially a pretty big problem is if the board has a separate plug dedicated just to GPU power that connects as closely to the card's location as possible. Which... kind of defeats the entire purpose anyway.
I have no doubt that this is to look neat, yes. It's also just a bit more convenient not having to run cords through to the GPU (might even help a tiny tiny bit with airflow, though usually they're pretty small except on dual power input GPUs.) Still, we're talking about potentially in excess of 50A passing through that board at times and even if it's split up pretty well that sounds like trouble brewing to me.I think I read that this custom motherboard has some connectors at the back so maybe that is the idea, to keep things looking neat? I'm not fussed about that personally though, as long as cables don't mess with airflow too much I don't mind what they look like as I don't have them on display!
As long ASUS's software doesnt f.. up and overvolts too much and fries the connector, the card and the motherboard.On the other hand, MSI is taking a more practical/novel approach by introducing "coloured" 12VHPWR cables.This idea and concept sounds pretty good though.
They are supplying coloured 12VHPWR connectors that use bright yellow plastic terminals. This coloured plastic is only visible when the cable is not fully connected to the 12VHPWR connector on your power supply or graphics card, so we can easily spot if the cables are incorrectly seated.
NOT connected properly. Yellow color is visible here.
Fully connected properly:
View: https://www.youtube.com/watch?v=d1WLq4arovo&t=2s
Most of the connector is one large "pin", not a bunch of tiny pins. Also, per my previous comment, the connector doesn't look that much different than what hot-swap server PSUs use and they push 1KW+ through those connectors. So again, this isn't without precedent.there's 600 watt going to go through those tiny pins?
woah, just a matter of time before something goes wrong
Well.. they put more attention and quality on datacenter than consumer.. so theres thatMost of the connector is one large "pin", not a bunch of tiny pins. Also, per my previous comment, the connector doesn't look that much different than what hot-swap server PSUs use and they push 1KW+ through those connectors. So again, this isn't without precedent.
Nah, card-edge connectors are pretty common for workstation PSUs (so swapping a dead PSU is as simple as sliding the old one out the back and the new one right in again), and those can easily push north of 1000W over a strip of PCB narrower than a PCIe card-edge.there's 600 watt going to go through those tiny pins?
