I have recently switched network providers to BT, with fibre to the box and copper into the house. I previously used a Sky router downstairs, with an Ethernet into a TP-Link power line adapter, then into a power line upstairs plugged straight into my N600's Ethernet WAN port. This worked great, and even worked when I switched over, but when I unplugged the router to move it, it failed to function again.
I got rid of the power line adapter and plugged directly into the new BT SuperHub 5 (I believe) and factory reset the N600. I then tried through Quick Setup, which didn't work, and through advanced settings, on both single Ethernet WAN and Dual WAN configurations. I have enabled PPPoE in the settings, as well as using the username 'bthomehub@btbroadband.com' with BT as the password. I also set another setting (I've forgotten it's name) to 101 as another forum post from another user recommended. Following all these steps, I have still been unable to get internet from my N600, it doesn't even seem to recognize an Ethernet WAN cable is connected. Please note, when the Ethernet WAN cable is plugged in, the ADSL WAN light on my router does light up and flickers (indicating activity I believe) but there is still no internet connection.
Any help at all would be greatly appreciated in the matter, as I need QoS ASAP!
