[SOLVED] Asus Dual GTX 1070 Fans Spin , Power Led White but No signal , Not Detected
Apr 25, 2021
Hey guys , i have a gtx 1070 asus dual , yesterday was working perfectly , and today when i power the pc on , it just doesnt work , the monitor shows no signal , the gpu s fans spin and the white led above the 8 pin is on , with integrated graphics works fine ( 650w psu )
I tried: reseating the gpu
Another monitor ( doesnt work , no signal )
Another gpu ( works )
Another pc ( still dont work )
Disabling the integrated gpu from bios( still no signal )
I put the gpu in different PCs with the same result , so please dont come with “check the ram , check the psu , check the PCIe...”
The card doesnt show on bios or device manager
Could a bios flash save my gpu?
Is there any thing i can do?
What you describe, is a dead GPU.
Unless there is another issue, other than the corrupt GPU BIOS, that doesn't help. And even if the issue is with corrupt GPU BIOS, you may not be able to "save" it. But you can try, if you like.
To save your old GPU? No.
To get your PC running? Yes. Either use iGPU or buy another dedicated GPU.
