Hello,
I have searched high and low without actually finding any type of answer as of yet. So here goes my question.
As I was playing Batman Arkham Aylum today, pretty much generally what I do for a an hour or so every morning, The game starts getting a little glitchy and then all of a sudden mid game my system just shuts down. It restarts itself and I get a on screen post
"The file may be corrupt. The file header checksum does not match the computed checksum"
Now, I had no idea what that meant, So I googled it and attempted a restart while I was searching. the second restart was unsuccessful as my system warning started to beep in intervals, which I have never heard before. So I do a cold shut down from the front panel and let the system chill out for a few minutes.
When I go to restart the system, There is no post-beep, the TV says no-signal and my 4870 is showing the three LED's D1601-1603 with the D106 unlit.
I have read on several places that this is mainly due to a PSU issue and to just replace it and everything should be fine. However my confusion is coming from the initial error onscreen post of the checksum. Which means I have bad ram right?
I have tried doing a BIO reset by removing the battery and trying the jumpers. I have tried running with only one Dimm of ram, I switched between each different one to see if a select one was an issue. I have switched out my graphics card for an older one. Nothing seems to work.
The question I have now is, Is it the motherboard the GPU or is it the PSU. I dont know anyway of testing each unit to see if they have fried or not.
This is what is in my Rig
Mobo - Gigabyte GA-M61P-S3
CPU - AMD 64 X2 dual core 5200+
GPU - Asus EAH4870 DK/HTDI/1GD5
Ram - CORSAIR XMS2 4GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X2048-6400
PSU - OCZ ModXStream Pro 700W Modular High Performance Power Supply compatible with Intel Sandybridge Core i3 i5 i7 and AMD Phenom
I hope I have given enough info, Thanks in advance for your time.
