Ok first off, if you are reading this... thanks.
Ok so i just built a computer for my g/f to play WoW on, its my first build.
Here are the specs:
Cpu: athalon mobile xp 2800+ 754 pin
(yeah sounds kinda wierd but thats what Newegg listed the mobo cpu combo as a 754pin athalon XP wierd.... I always thought xp's were all socket A)
Mobo: PC Chips M871G (v1.5)
Ram: Gskill 1gb drr400 x1 and kingston value ram 512mb x 1
HDD: 120gb ata Seagate harddrive
OS: Win XP home
GPU: asus Nvidia en6800 512mb ddr2 AGP
The system runs fine until i attempt to install the drivers for the gphx card. I have windows completely updated, I have updated the SIS AGP GART driver from the PC Chips website, tried the latest non-beta drivers from nvidia, nothing seems to work.
What happens: when the drivers are installed they finish the installation correctly. The system boots fine, the windows XP loading screen comes up (the whole sliding blue bar thing). I sit there expecting the windows welcome screen to pop-up but instead 1/2inch thick yellow and/or blue distorted (torn) verticle lines appear alternating between yellow and blue for about 10-15 seconds.
The system hangs with a blank screen (but it still has backlight) and I have to dry reboot it, booting into safe mode and removing the drivers.
Any ideas? I would appreciate ANY advice.
Here are the specs:
OS: Win XP home
