Hello,
I've built a system with the Asus Z87-A motherboard. The system has 3 PWM case fans and the Arctic Freezer 13 as the CPU fan. The CPU fan is a 4-pin PWM fan as well.
I have a problem with the Asus Fan Xpert 2 software (part of the AI suit 3). I can control the 3 PWM case fans, but I cannot control the CPU fan through the software. While the software is installed, the CPU fan is always running at max speed. The speed-temperature graph through which you control the fan speed at different temperatures is grey, and I cannot change the speed of the fan in any way. However, I can see the RPM of the fan.
I've tried running the auto tuning from the xpert multiple times, but nothing changes. It does recognize the case fans and modifies their speed graphs, but the CPU fan remain at max speed all the time.
I can control the CPU fan speed through the bios just fine, so its not a hardware issue. However, the Fan Xpert overrides the Bios settings, so even if I modify the fan speed at the Bios, as soon as I go to windows the CPU fan is back to full speed.
I had to uninstall the fan xpert, and disable the asus fan control service, to prevent the CPU fan from spinning at max speed all the time. Now the fan's speed is dependent on the CPU temperature, as it should be.
I tried updating the Bios to the latest version, as well as installing the latest version of the AI suit, but that didn't help.
Any ideas?
Thank you.
Any ideas?
Thank you.
