Asus Geforce GTX 750 ti oc 2GB ( Horizontal monitor scan lines/flickering )
evyosh
309
Guy this is the best example that i can show you what happening to with my monitor philips 200V https://www.youtube.com/watch?v=VFN5gy2BY_w
im using Dual Monitors both monitors are the the same. (Monitor-A) with DVI-D & (Monitor-B) with VGA. the one with the DIV-D doesnt have the issue.. the one with the VGA cable is the one has the issue. to check if its the monitor i exchanged cables. and the other monitor start having the same issue.. so in short DVI-D cable is the solution. so now my question is.
with me ASUS Geforce GTX 750 ti oc 2GB can i use both DVI-D at the same time to extend.
this is my card it has 2 DVI-D, 1 VGA, 1 HDMI = http://8lien.com.au/catalog/images/default/VCX-ASU-GTX750TIOC2GD5.jpg
Theoretically you can use all three, minus VGA, simultaneously for an extended desktop.
If your monitors don't support the appropriate connection types, buy adapters.
