ASUS GTX 1060 - Fan Broke, Help!
adamcurpier
21
Hey all, first post, long time lurker.
I was installing an Asus 1060, 3gb, Dual Fan GPU (the one with the white case), and I accidentally put pressure on a fan blade. Yes, it broke off 🙁. So now a piece is inside. When the fans ramp up, the whole card is now shaking. I'm really P*** off at myself. Anyway, I need some help sourcing another fan, a matching one, quickly. Please help!
-Adam C.
I dont think fans are sold to replace the ones that came with the GPU
1. Try to see if running with single fan works
2. Go on ebay and try to find a fan that fits
3. Get an aftermarket cooler
Did you find the fan?
I too need one and haven't been able to get one.
Thanks!
No 🙁
Hi,
I recently had a 1070 strix that I broke the fan blade on. It was under warranty and Asus wouldn't do anything to help, so I just ordered a new fan on Alibaba express and it looks like the original fan, down to the stickers. Installation is pretty easy, but it's different depending on what fan broke. Each of the three fans takes a different cable so I'd imagine it's the same with the duel. There should be a 'a' and a 'b' fan, find out which one needs to be re placed and order it on Alibaba or eBay, I think they use the same fans on strix and duel.
