Asus gtx 680 power consumption
gray0909
23
how much power would 2 direct cu2 OC gtx 680. i currently have a 750w and want to add another gtx 680
my specs are
i7 3770k
asus maximus v formula
dc2o gtx 680
16gb 1866mhz gskill ram
corsair h100
and 5 led fans
would my power suppyl be enough?
Well it depends if you have a good psu or not
GeForce GTX 680 - On your average system the card requires you to have a 550 Watt power supply unit.
GeForce GTX 680 SLI - On your average system the cards require you to have a 750 Watt power supply unit as minimum.
If you are going to overclock GPU or processor, then we do recommend you purchase something with some more stamina. http://www.guru3d.com/articles_pages/geforce_gtx_680_review,9.html
also would overheating be a problem? if i do add the 2nd card, there would only be about 1/4 of an inch between one another. right now my single card peaks at 60 degree C
mmm antecs are a mixed bag. depends on which PSU as they re-badge PSU's from other manufacturers. that said the one you have in particular seems to be fairly decent one. it should work but i wouldn't rule out a higher wattage one if you can swing it in your budget. if you can't i would not worry to much.
It will most likely heat up a few C more, but it shouldn't be an issue.
If you get the opportunity invest in something with higher watts later.
