In amongst a pile of stuff I got was the above referenced motherboard. It, alongside two other boards failed my initial function testing. I took some time to go through them with both 6th and 7th gen CPU and where two of them will not boot up this one ended up working with a Celeron G3900 CPU I have on hand. I used that to flash the BIOS up to version 1102. I installed W10H and it activated so it was using that OS whenever its last use case was.
Support page:
www.asus.com
I actually had a bit of a time finding the proper support page as it appears this motherboard came from an ASUS VivoPC "M32CD". Searching that motherboard model on ASUS support site only returns an H110i-plus model of which the BIOS revisions, USB drivers, and sound drivers do not work. I luckily ran across a Reddit page where someone was referencing this motherboard and then to land on the Vivo support page above.
Everything is loaded in, got USB functionality to work, got the chipset driver(s) to opt from. This mobo has both an analog and a digital output covered by Realtek drivers. It will "see" when I connect or disconnect the analog speaker for the rear panel. If I look further in such as the sound mixer it will show that it thinks it has audio output by the green meter (as it were). There is no sound output via the analog onboard.
I don't currently have a case to utilize for testing, so no available front panel connector, and cannot bring an HDMI TV to the motherboard, so I cannot test to see if it will output sound that way. I have variously tried other drivers, delete the driver(s) and let Windows use its automatic loads, used the troubleshooter and so on.
As mentioned above, in spite of the BIOS update I cannot get any other CPU to work in this PC. I have tried a Pentium G4620 and an i3 7100 as well as two other Celeron of the same model. (Those CPU all work in another mobo I have aside from the Pentium G) Since this came in a prebuilt PC, the only thing I can find indicates this likely came with a 6th gen i5. The site has no CPU compatibility listings, but there are drivers and BIOS updates marked specific to Kaby or Skylake. I have tried each one of the available drivers for sound, rolled back the chipset drivers, pretty much everything I can think of.
I guess, long story short, is it possible for the onboard "amp" to go out but the device continues to think it is working properly?
Is it possible there was any manner of proprietary silliness going on with the original ASUS case?
Support page:
M32CD - Support
