ASUS H110M-A M2 Front panel connections
robguay
Need help with Front panel connection on the H110M-A M2 motherboard. I heard if you do it incorrectly you can fry the motherboard. The link is an image of how I think they should be plugged in.
1) Does this look correct?
2) Do the letters (on the plugs) face the processor or away from the processor? I assume away because the positive pin looks to be the one on the far left.
3) Do I skip a pin between the HDD and Reset? Because there are only four slots/female inputs total on the two plugs. So a pin has to be skipped some place.
Thanks a million for any help
Thanks I could not find that manual. :bounce:
Thank you for your reply, been a while since I built a machine so I wanted to make sure I did not mess up. :pt1cable:
You're welcome.
