I'm having some trouble with the motherboard I recently bought for my first build. I have looked at the physical instruction manual it came with, as well as the one online.
The case I'm using is a Bitfenix Mini ITX.
I can't seem to connect the cords such as POWER SW and RESET SW. The system won't power on.
I did the POWER LED+ and the POWER LED-, however they do not work in the places the manual had shown. I switched then around a bit and they're working fine now. Which is why I've become rather lost and frustrated with the instructions.
Thank you for the help. (If for some reason this is the wrong category, I apologize.)
