reedo_43 Splendid Feb 18, 2010 6,195 3 29,965 Sep 30, 2015 #2 Have you tried all ports? Did you install usb 3 drivers? Upvote 0 Downvote
jimmysmitty Champion Oct 5, 2007 21,595 594 59,140 Sep 30, 2015 #3 We need a bit more info than that. What OS are you using? What USB ports are you using (USB 2.0/3.0 etc)? Are your mouse and keyboard working? Upvote 0 Downvote
T Turbo20VT Reputable Aug 25, 2015 25 0 4,530 Sep 30, 2015 #4 Sorry I mean H87M-PRO. I RUN Win 7. Yes, Mouse and Keyboard working. I Used USB 2.0 and 3.0 Front as back. For mouse/keyboard I use 2.0 ports. Upvote 0 Downvote
reedo_43 Splendid Feb 18, 2010 6,195 3 29,965 Sep 30, 2015 #5 Does it work in the port that the keyboard is in? Upvote 0 Downvote
jimmysmitty Champion Oct 5, 2007 21,595 594 59,140 Sep 30, 2015 #6 Test the working ports but also check to make sure you have the latest USB 3.0 drivers from Intel: https://downloadcenter.intel.com/download/24896/USB-3-0-Intel-USB-3-0-Driver-for-Intel-NUC Upvote 0 Downvote
T Turbo20VT Reputable Aug 25, 2015 25 0 4,530 Oct 1, 2015 #7 Nothing, I installed that driver, IT can see the USB-sticks, in Device Manager... Upvote 0 Downvote
jimmysmitty Champion Oct 5, 2007 21,595 594 59,140 Oct 1, 2015 #8 What about Disk Management? Can you see the USB drives there? Upvote 0 Downvote
T Turbo20VT Reputable Aug 25, 2015 25 0 4,530 Oct 1, 2015 #9 Yes Jimmy, I can see it there.. Upvote 0 Downvote
jimmysmitty Champion Oct 5, 2007 21,595 594 59,140 Oct 1, 2015 #10 If you can see it there it sounds like it is working but for some reason it is not assigning a drive letter. If you right click on the partition of the USB drive can you assign it a drive letter? Upvote 0 Downvote
T Turbo20VT Reputable Aug 25, 2015 25 0 4,530 Oct 1, 2015 #11 Sorry, it doesn't show. I saw unnlocated , but that's not from the USB. Upvote 0 Downvote
T Turbo20VT Reputable Aug 25, 2015 25 0 4,530 Oct 1, 2015 #12 Sorry, it doesn't show. I saw unnlocated , but that's not from the USB. Upvote 0 Downvote
