ASUS keyboard problems-right side errors
NickGabr
Commendable
Mar 25, 2016
Right side of my ASUS laptop does not work well.
For example key "l" is reacting like "ùl" (in French register) or "'l" in US layout, key "m" as "àm" or "0;" and so on.
Most keys on the right side of keyboard are assotiated with a wrong symbols.
At the moment using external keyboard.
Any solution please?
Hi, try to remove gently the ribbon for the keyboard from the motherboard, you will have to push up or sideway a piece of the connector, be careful not to break it. After reconnect the ribbon push back the piece and try again the keyboard.
Make sure your laptop is set to English(US) When I first got my Asus laptop, I had the same problem. I went into the settings and made sure my keyboard was set to English, which solved the problem.
