Asus laptop ROG G53sx FAN constantly running at max speed
ttengg
4
Asus laptop ROG G53sx FAN constantly running at max speed both CPU and GPU fan
it happen after i clean my heat fins using vacuum cleaner
the CPU and GPU temp is under 40c so its not over heating
what i tried
download speed fan , no luck it wont let me set the fan speed using program
re flash the bios using CMD /nodate
remove Cmos battery ,laptop battery press power button 30 sec , still no luck
any suggestions/solutions?
Thanks in advance
Hi,
Did you apply a new thermal paste when you clean the fans? I would suggest changing the thermal compound on both the GPU and CPU that may help in solving the issue. After applying a new thermal paste, do install all important updates there is as well. Do also install the latest BIOS update there is from Asus Support site.
https://www.asus.com/nz/Notebooks/ROG-G53SX/HelpDesk_Download/
ttengg
4
thanks for quick response
thermal compound still looks good to me , i checked the laptop temperature using speed fan system runs cool , i believe its not over heating
laptop is in latest bios version 209 , i already did re-flash it nothing happen , i wonder downgrading bios to old ver 208 my fix the problem or i might brick my lapy?
screen shot of my core temp and gpu
<img src="https://www.imageupload.co.uk/images/2015/12/26/speedfancool.png" border="0">
ttengg
4
thanks for the reply
yes this laptop have 2 fan in board already switch them nothing happen :(
