1. MyASUS app keep bothering me wants me to update something everytime I boot my laptop
2. I need myASUS app so I can set my battery max health/lifespan mode, upon uninstalling it reverts back to asus default battery plan which increases wear level of my battery as shown in hwinfo, laptop is barely 3 months old, it is already 4.3%. Laptop orange light indicates charhing when plugged into wall, laptop consumes charge when turned off also when plugged in. Lights indicates that
3. When I use myasus app, max lifespan mode protects battery health as far as I see in status lights by not charging everytime. Uninstalling myasus app reverts that, which damages battery
4. Armory Crate doesnt work properly even when installed cleanly, Manual fan curve cannot be set and/or it conflict with windows power plans. I don'want to remove my custom made power plans just to make it work asus software. I want to use both in same time.
5. Armory Crate did suddenly increases everything during manual fan curve status, both voltage and temps rises in seconds. Same in BIOS as well, cannot take a look into my BIOS settings because laptop cooks itself to the death when I inside of the BIOS.
6. Armoury Crate "slient" power plan does the same, both voltage,temps magically doubles in seconds so there is no time to set things right cuz laptop literally nearly fries itself if I dont switch back to "windows" template which corrects the errors I mentioned then everything went back to normal in seconds
7. This is a asus zep g15 rog ga503rm, fans starts spinning at 60c, both gpu and cpu, I guess thats normal, because there is no way to control ny fans on this cursed laptop. Dont want to use fancontrol as it modifies control settings
8. I need myasus so I can contro battery but updates keep makes things worse I dont even know what or which update is these, I do NOT want to update anything. I turned off essential updates from myasus app settings, did not do any difference.
Is this laptop cursed somehow? Why I'm having these strange problems after paying like a fortune? Can anyone help?
