Asus laptop Won't turn on and not showing any light indicator...
Hello_1_2
Commendable
Aug 7, 2016
Hello,
My Asus k55vd laptop is not starting up and when i press the start up button. It does not show any light in the indicator... i tried the reset solution by presing start up button for 30 seconds without the battery.at first it works fine but after i shut down the system.. it does not start... i tried the reset solution several time.. but now its nothing... please help
Try the following and see if it will turn on.
1. First make sure the device has been charged.
2. Unplug your charger cord.
3. Remove the battery.
4. Press and hold the "Power" button for 30 seconds and see if the device will turn on.
5. If it does, great, now plug back in the power/charger cord. (If it didn't turn on without the cord in, it should turn on once you it is in. Yes sometimes they will turn on, or try to turn on, even with nothing attached/plugged in.)
6. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop.
Should that not be the problem, then check the battery to see if it needs replacing...
From there, if it is still not working, then you may need to open it up and find out the problem. Or take it to a local tech/repair shop.
