Unless the rear jacks are faulty, the front headphone jack might not be releasing when you remove the plug from the headphones. The audio is usually set up where the front jack disconnects the rear jacks when in use. Open your case and find where the front audio cable plugs in on the motherboard. Remove it and see if you get your rear jacks to work. If so, the front jack needs replacing.
