I'm brand new to these forums - I need some help.. :-\
System specs:
AMD Phenom II X6 1100T Black Edition Thuban 3.3GHz, 3.7GHz Turbo Socket AM3 125W Six-Core Desktop Processor HDE00ZFBGRBOX
ASUS M5A88-V EVO AM3+ AMD 880G SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
OCZ Agility 3 AGT3-25SAT3-60G 2.5" 60GB SATA III MLC Internal Solid State Drive (SSD)
Rosewill Xtreme Series RX850-S-B 850W Continuous @40°C ,80 PLUS Certified, ATX12V v2.2 & EPS12V
v2.91, SLI Ready CrossFire Ready, Active PFC "Compatible with Core i7, i5" Power Supply
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CMZ8GX3M2A1866C9
Sentey Arvina Extreme Division Tower Case 6x Fan LED/ 4 x USB / Multi Card Reader / 4 x Fan Control / E-SATA / 6 x Removable Aluminum Bays / Screwless
ZOTAC AMP! ZT-40102-10P GeForce GTX 480 (Fermi) 1536MB 384-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
!!!! STOCK CPU COOLER !!!!!
Alright, The problems I'm having : I can't overclock over 3.755ghz. When I do windows freezes on boot animation or it bluescreens right after. Auto-clock managed to get it up to 3.8-4, but it wasn't stable (temps were stable, but using the stability test on AMD Overdrive bluescreened it within seconds.)
Also.. I'm not sure if this means anything but CPU Levelup is grayed out and bios says something about the cpu not being valid for levelup.
When I get it above 3.8, the bsod says something about a "secondary" core clock not responding in time :-\.
I greatly appreciated help
(NOTE : I would like to just get the CPU running at 4ghz, and.. I would like to figure out what's wrong with it, if anything :-( )
PS. Windows 7 - 64bit - Ult.
System specs:
