Hello,
I am writing here because I am out of ideas what could be wrong or what else could I do. I would appreciate any suggestions...
The computer won`t boot.
A red CPU LED light goes on when I push the power button.
After pressing the MemOK button a red DRAM light starts flashing.
The monitor is black.
The CPU fan goes on.
Things I have already checked:
- plugins (24PIN and 8 PIN)
- removed the memory and tried to put it in every slot (both and one at a time, doesn`t work. The memory sticks are ok because I`ve tried them on a second computer, swapping the sticks from the second PC is useless)
- removed the graphics and tried another one in the second PCI-E slot (no good)
- checked the CPU (all pins are OK, everything is attached properly)
- removed the battery from the mainboard
Hardware:
Case:Silentium Gladius M40
MB: ASUS M5A97 EVO R2.0
CPU: AMD X8 FX-8350
CPU COOLING: SilentiumPC Spartan Pro HE924
GRAPHICS: ASUS GF GTX970 4096MB 256bit PCI-E DirectCU II OC
MEMORY: HyperX 2x8GB DDR3-1600 Dual Chanel Kit Non-ECC CL9 XMP Savage Series HX316C9SRK2/16
POWER SUPPLY: AeroCool VP-750
Is there anything else I can do?
Thank you for your time
Hardware:
CPU: AMD X8 FX-8350
