Asus M5A97 LE R2.0 running hot?
MrMachoWendall
70
I was wondering if these are normal temps for this board being @ 3.6GHz and my CPU socket is at 93 F. Back when it was at stock speeds I used three different temp programs and they all came up with different results. Bad sensors? Maybe?
I have a FX-6300 btw sorry. Plus I did put vrm heatsinks on this board too. The LE version doesn't come with any. I'm also using a Cooler Master Hyper Evo 212
78-93 F for the socket and 50-55 F for the CPU running at 3.6 GHz
Are you sure this isn't Celsius? Your cpu is not at 50-55 Fahrenheit unless your room is like 40 degrees Fahrenheit.
Now its at 18 C and socket is at 37 C
Well yah that cant be right something is wrong its impossible for your cpu to be that cold unless its freezing wherever your computer is or you have a liquid nitrogen cooled pc that you forgot to tell us about lol.
Senors maybe?
