Hi - this is my first post so would really appreciate some advice on my problem.
I have an Asus M5A99X EVO motherboard with a Radeon sapphire 5450. Running windows 7 64 bit.
I have been trying to change the Sapphire to a EVGA Geforce GTX 750 Ti single fan card.
I have updated the motherboard BIOS to the latest version.
I removed the Sapphire card and installed the 750Ti and connected it to an Asus PB287Q monitor by HDMI.
This is the problem:
When I switch on the computer I cannot get past the initial ASUS "welcome" screen where it says "press DEL to enter set up". And nothing happens if I press DEL. On the asus motherboard the Boot device LED continues to show constant red.
This also happens with my Dell monitor.
I have scoured all the on-line advice but have found nothing that helps so far.
Any help would be gratefully received.
Thanks in advance.
Thanks in advance.
