I completed a build recently and while using the machine, I'm getting the following numbers while gaming on an ASUS Maximus Hero VII and 4790K processor using Noctua U12S air cooler, all running at stock:
HWiNFO
4970K CPU: min: 37; max: 59; avg: 49
GTX 970: min: 33; max: 62; avg: 56
The numbers are fine. Not too high, could be lower if had water cooling, but they are fine. However, I wouldn't mind them being a little lower just for longevity (and the only restart I've had was when running The Valley bench while afk, so don't know what happened).
I don't want to mess with the BIOS values for voltage, timing, etc. as I don't know what I'm doing.
Can I just turn off Turbo Boost somewhere to see how temps change? (I can't find where on ASUS bios) Anything else to turn off I might not need that can affect temps?
Second thing, and it's unrelated, but do I need Intel Virtualization Technology setting enabled to use things like VMWare? I've not tried yet, I just noticed it was disabled by default.
In Googling this, I thought the answer to both would be simple yet...no luck on my end making real sense of it 🙁
Thanks in advance!
HWiNFO
Thanks in advance!
