Asus Monitor Color Problem
Apexx_iPredator
Hello, I have a Asus VS238 x2. I had the 1st one for about a year and just got the second one. When I plug the second one in the color is off. The settings are the same. I did get it replaced with a new one, but still same issue. I have a Asus GTX 660 Ti. I tried plugging in different desktop, same problem. So I'm not sure what to do?
Some manufacturers will not have a consistent color production in each monitor even if it is the same exact model! 🙁 Which is why expensive premium monitors like Eizo, NEC, and LaCie do this and you certainly pay for it. I doubt ASUS as they focus on gaming perspective would take the time and energy to do all this, so you will have to do your best to match one monitor to the other by going through brightness, color, and etc settings to get the best possible results. Hope this explains more. :)
Its near impossible to get a perfect colour accuracy monitor, by the same token its near impossible to have two monitors with the same colour accuracy.
Most I can recommend is you get some kind of calibration tool and run it on both screens so that colours display roughly the same across both.
