J Jct Reputable Apr 2, 2015 149 0 4,690 Dec 16, 2015 #1 Can you use any power cable to power a monitor or are there ones specific to each monitor? The monitor I need to buy a cable for is an ASUS vs228 Thanks
Solution kanewolf Dec 16, 2015 It the end that plugs into the monitor looks like this then any power cord will work. Monitors are very low power.
kanewolf Titan Moderator May 29, 2013 38,445 3,705 156,790 Dec 16, 2015 Solution #2 It the end that plugs into the monitor looks like this then any power cord will work. Monitors are very low power. Upvote 0 Downvote Solution
