make sure the mother board is sitting on top of the standoffs. on the edge of the mb near the heat sinks is the eight pin power plug filled. look at the motherboard serial number label. the last four are the bios rev. the newest bios is 2201 if your is real low. download the 2201 bios and under bios tools download the bios renamer. put the renamer program into the same folder as the bios and run it it will rename the bios from 2201.cap to a name the usb flashback is looking for. put the bios on a usb stick and pulg it into the usb flashback port and hit the flashback button. you see the light blink for a few min and then turn off.
