have a PC that i custom built, that has started bugging me to NO end. the more i learn about what is wrong with it, the more confused i get. i am at the point where i haven't a CLUE what is going on. i have been trying to track this problem down for about a month and a half.
i have an Asus P8Z77V-Pro
intel Xeon E3-1240V2
Gskil Ripjaws 2x4 GB ddr3 1300MHZ
Asus Gtx 760
Corsair AX760i
Corsair H80
WD green 1.5TB
Kingstone 128GB
a myrid of different fans,
and all of it packed into a NZXT Guardian 921
i can provide links to all pieces if you need.
what this thing has started doing is not booting. specifically it will sometimes randomly shut itself off durring work. when i go to reboot it, it will power on for a second, just long enough to power all the pretty blue fans on, then instantly shut off. about 3 seconds later, it will power back on, then of, and repeat till i kill the main power. i have already replaced the AX760i, and the Motherboard is only 3 days old, after having it sent back with the same problem.
for a little while on the old MB i could get it to start by clearing the CMOS, but after about 6 times, that failed all together and quite working. this time, i found out that i could turn the PSU off. unplug the 20+4 and the 4+4 wait a few seconds, and plug them back in, BINGO it worked. but I'm afraid that tomorrow morning it will do the exact same thing. is there any thing i can do to A, figure out what on earh is wrong, and B, get it fixed?
Asus Gtx 760
Corsair AX760i
Corsair H80
WD green 1.5TB
Kingstone 128GB
