Asus MotherBoard Green led not powering on / Turning on. but PSU work on different PC
yokai15
5
I just bought a Asus motherboard H81m-D 1150 socket
the last activity i do was after i plug a USB my computer power's off suddenly then i remove the USB then turn on again my computer. and it run well. i play games before i leave
So i leave my house for about 5 Hours when i go back my computer is turn off and my Gaming mouse led is blinking for 1 sec then off for 5 sec there's no component powering on except from my mouse led's blinking and when i turn on the computer. it is not powering on.
i thought my PSU has a problem when i transfer my PSU on a different computer it is still working
and then i try again puting back my PSU on my real computer. it stills not powering on and my mouse led is blinking.
So i think that the issue is in my motherboard
Please help me. i have lost my Recipt paper and i cannot bring back this mobo anymore in the shop where i bought it.
Sounds like you need to plug-out main power cable, open your case, remote the the RAM, clean the socket, put them back, Make sure your hard disk cable are also plug in properly. Then try to start. Usually these kind of problems are cause by RAM reading problem on computer start up.
You need to see your PC is not over heat and always make a proper shut-down for such a long our gone.
