Hi
My asus m5a99x evo r2.0 that I got today doesn't seem to be working? Or is it the ram?
All the fans spin, don't stop spinning, but the dram led light isn't on. The cpu led flashes, and then turns off, and the boot device led is on, so it's definitely not the hard drives or cpu, I don't think.
It's probably not the gpu because I used that yesterday, and it worked fine.
I've tried:
. Changing ram slots/configurations (A1 + A2, B1 + B2, A1, B1, A2 + B2, A1 + B1)
. Taking out storage sata cables (didn't change the issue)
I know my pc isn't posting because my motherboard speaker doesn't make any sounds, and the led on my mouse doesn't light up. The motherboard does seem to be working though, as my led strip and USB fan both work, and my speaker led turns on
My specs (atm)
Mobo: Asus m5a99x evo r2.0 am3+
CPU: Phenom ii x6 1090t
RAM: 8gb (4x2) DDR3 1866mhz dual channel memory (HyperX fury)
GPU: Gigabyte GTX 960 2gb
Storage: x1 128gb 2.5" sata laptop hard drive (fujitsu), x1 WD 1tb sata hard drive
This is an urgent issue as I need a working pc for my work, and cannot do it from a phone.
Thank you,
Benjamin Lambeth
I've tried:
My specs (atm)
Thank you,
Benjamin Lambeth
