Asus Motherboard Red Cpu and Dram LED
TheHow NotTo
11
I have recently attempted to build my first pc, unfortunately I have run into a few problems. First let me start off by saying I wanted this to be a basic streaming pc that could be upgraded later when I got the money to do so. Whenever I start it up the fans and lights all turn on but their is no signal going to the monitor, the cpu and dram led flash (alternating between the two)
I checked all the connections took everything apart and put it back together with just the bare minimum (1 stick of ram, cpu and cooler, ssd only, and the optical drive) and still got the same thing.
Here are the specs:
Tower/Chassis: NZXT SWITCH 810 White
Cpu: Intel Core i7-4790K 4.1 GHz
Motherboard: ASUS Z97-PRO
Ram: Corsair Dominator Platinum 32GB
Psu: NZXT HALE90 V2 1200W
SSD: Samsung 250GB SSD
I do not have a gpu yet but I do plan on getting one, If I can get this to work 🙁
I am also new here so I don't know what you all need to know for sure.
Hmm, that is very weird. Almost any RAM should work with your board, including the RAM you have. The RAM listed as compatible in the manual is just RAM that Asus tested themselves, and they can't test every stick out there.
I honestly would not know. I can always try with 2 sticks. I look at the numbers displayed on the board and it has the standard installing cpu and stuff like that but then it gets to the ram and briefly flashes the code for ram incompatibility. Is their a way to reset an overclock on ram or not? Im sure that is one of the problems.
So I went and wrote down all the Q codes that are displayed on the board and this is what I got (in order of how they are displayed)
00
21
33
35
37
3E
3A
3C
39
9F
40
58
then it goes back to 00 and does it all again. I looked these up and the only one that sounds wrong is the 58 which according to the motherboard manual and it says "CPU self test failed or possible CPU cache error"
Have you made sure the RAM is correctly seated? Sometimes it takes a lot of force before it clicks in properly.
Try different RAM slots if everything is seated correctly and see what happens. If the CPU POST light is on, try removing and reseating it as well.
Does the CPU POST light blink when there is no RAM installed?
Try removing the CMOS battery for 10 - 15 mins. It shouldn't take that long to reset the BIOS, but may as well be sure it is reset.
without ram in the Q codes displayed are 00, 13, 15, then FE. It essentialy does the same thing though (starts up fans, then cpu light flashes then the dram light flashes) and I have updated the bios though usb bios flashback, I have tried removing the CMOS battery, I have moved the jumpers ext. I am getting worried I may have gotten a bad part.
I would like to know as well. Pretty much any RAM should be compatible with that board.
I don't think any RAM (available for sale) runs over 1.65V, which is fine with a 4790K. Unless it was defective, I'm not sure what he means.
I ordered the CMD32GX3M4A1866C10 version of the ram. According to the manual it only supports CMD32GX3M4A1866C9. The timing of the ram I ordered was incompatible with the motherboard I have.
A friend and I did some trial and error runs with it and found out it was the problem. When we take out the ram the Q-code displayed is FE. And since that is displayed it means the cpu is working but the ram is not/not being picked up by the board.
Ok sorry for being gone for so long, I was waiting for the new and proper ram. So I put all the ram in and I get these codes in this order. I labled them with what the mauel said but im not 100% as some of them are not listed (ie 21 is not in the book)
00 - not used
21 -
33 - cpu-post memory initialization
35 - cpu-post memory initialization
39 - post-memory system agent initialization is started
37 - post-memory system agent initialization is started
38 - post-memory system agent initialization is started
3e - post-memory PCH initialization is started
3a - post-memory system agent initialization is started
13 - pre-memory cpu initialization is started
15 - pre-memory sytem agent initilization is started
00 - not used
Also still no signal on the monitor and no post.
I've got the same problem, except...
I have an ASUS Z97-A USB 3.1 with a Intel Core i5-4590 3.3GHz and corsair Vengeance Pro 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (CMY16GX3M2A1866C9R)
Everything was working fine for about 2 weeks. Then one day, out of the blue, it wouldn't boot up. I opened the case and saw that the DRAM and CPU LED's where flashing alternately. The manual says that if there is a fault that the LED will be steady, not flashing. Flashing indicates either the boot process or that MEMOKAY is testing various settings. Well, I haven't messed with any settings. So, the only thing that changed before the failure is regular software patches. Maybe a patch to the ASUS MB monitoring software changed?
I had the same issue with my motherboard but the cpu led does not blink after taking out the ram.
It would be best if you tried the things in this thread and then started your own thread.
