Question asus mx239h screen problem
Sep 12, 2020
asus mx239 screen problem after power outage, discoloration appears when watching videos, moving the mouse, I tried with a tv and the pc is giving the signal well, it's the monitor I'm sure, someone knows what is the fault or the part that It hurt because when the screen is still I can see well, but I need to know what happened
Can you try another monitor to see if you still get this problem?
if I currently connect the pc to my 32-inch tv
Can you try your monitor with another PC?
yes and it throws the same error
I took the monitor to a local technician and he told me that the main board burned somewhere and causes the failure, the problem is that I have not been able to find that piece of hardware for mx239h I have only seen for other monitors like the vz239 series .. on the internet (ebay and those sites)
