ASUS Optical Drive Problem!
KtgPlayz
Commendable
Aug 5, 2016
I Have A Asus 24x DVD-RW Serial-ATA Internal OEM Optical Drive DRW-24B1ST And I Was Installing Black Ops 3 And I Had Restarted My PC While It Was Installing And Now It Doesn't Read Discs! I Have Tried Deleting Lower And Upper Filters, I've Tried Uninstalling It And Still No Luck! Can Someone Please Help Me?
(Optical Drive Link)
(https://www.amazon.com/Asus-Serial-ATA-Internal-Optical-DRW-24B1ST/dp/B0033Z2BAQ/ref=sr_1_1?ie=UTF8&qid=1470449039&sr=8-1&keywords=ASUS+Optical+Drive
Have you tried uninstalling and reinstalling the drivers? Head over to Device Manager (Hit the Windows key + R at the same time and then type devmgmt.msc) and see if it is shown there. If it is, try updating it.
If it does appear, then head over to the ASUS website and get the drivers here: http://www.asus.com/US/Optical-Drives-Storage/DRW24B1ST/HelpDesk_Download/
Just choose which OS you have and then run the program. Restart your PC and then it should work.
