Build
CPU: Intel I7-14700K
Motherboard: Gigabyte Z790I Aorus Ultra
GPU: Gigabyte 4070 Ti Super Windforce OC
Case: Lian Li A4 H20
Budget: N/A
For this build, I was aiming for a 850w PSU. However, the PSU selection at the Micro Center nearby is thin. They don't have any Lian Li that are black and 850w while their Micro Center house brand option gets poor ratings. My remaining choices are an ASUS ROG 850w Gold SFX-L, an ASUS ROG Loki 1000w Platinum SFX-L or a Cooler Master V1100 11000w SFX.
I know that the Cooler Master is overkill wattage wise, but it will fit the case the best as it's an inch shorter in depth. The Cooler Master is also more than future and upgrade proofed. Are there any disadvantages here beyond increased cost? It's $60 more than the ASUS 850w and $80 more than the Phanteks 850w Platinum that I had originally selected.
I could shop elsewhere, but I want to use Mico Center's build service.
Thank you
Budget: N/A
Thank you
