[SOLVED] ASUS or DELL 75Hz IPS monitor? NEED HELP!!!
Apr 29, 2021
Hi, I'm currently eyeing on getting a 24 inches monitor. I have found 2 similar monitors but different brands. Can anyone suggests me which is better in terms of reliability and quality? Thanks
1. ASUS VZ249HEG1R
2. DELL S2421HN
I personally would go with the dell only for the second hdmi port, aside from that these two monitors seem very similar feature wise. What are you wanting to use the monitor for?
I just want to make this monitor as a second display for my laptop because I think my laptop display size is too small for long term online learning usage.
