ASUS P4P800 SE does not power down, at leats not for my ou..
G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a 8-socket outlet where 1 socket is the master having a threshold
of 15W. If the power consumption of the master socket is less than 15W,
the outlet will switch off all 8 sockets.
When I attach my new computer with a ASUS P4P800 SE motherboard to the
master socket, the outlet does not switch off all 8 sockets when I
shutdown/powerdown via Windows XP: my monitor goes into suspend mode and
my modem/router stays on. Apparently the power consumption of my
computer is still larger that 15W. Only when I push the on/off switch at
the back of my computer, the outlet switches off all my components on
the 8 sockets.
How can I fix this?
By the way, the outlet worked with my old computer with a different
motherboard and Win98SE by shutting down Win98SE. I also upgraded the
BIOS of my new motherboard to the latest version.
Jur Schuurman
"Fam. Schuurman" <jur@nospam.nl> wrote in message
news:40A75E2A.DDF88569@nospam.nl...
I'd love to find a powerbar like this in Canada (or even toss one together).
Any suggestions folks?
No, alas, the outlet has no power adjustment, it is fixed to 15W.
As I have a PS/2 mouse and keyboard, I do not need a USB waking
capability.
Also, I do not need a wakeup LAN.
Is it possible to switch off those waking capabilities?
Jur Schuurman
In article <40A7BC7E.6BBCFB86@nospam.nl>, "Fam. Schuurman" <jur@nospam.nl>
> capability.
> Jur Schuurman
Note: These are usually the default setting from the factory.
KBPWR - Set jumper to +5V
USBPW12 - Set jumper to +5V
USBPW34 - Set jumper to +5V
USBPW56 - Set jumper to +5V
USBPW78 - Set jumper to +5V
"Power On By PCI Device" [Disabled]
The onboard LAN chip could be powered by +5VSB, to support the
wakeup function. Maybe you could try disabling the Onboard LAN,
then attempt a shutdown and see if the power is reduced enough
to work.
"Onboard Lan" [Disabled]
While there are some transistors used on the motherboard
to control power flow (like the ones connected to the
fan headers), I don't know if that technique is used on
any of the motherboard chips or not. Some chips have a
disable pin, and many chip designs are filled with power
saving features, so it probably isn't necessary for Asus to
switch off the power flow to the chips using a pass
transistor.
Paul
