I recently got an old motherboard for free from a friend, I know it works and I was going to try and build an old Core 2 Duo system with it. I got everything plugged in and turned on, but it fails POST with 2 beeps.
I've been reading that this was about ram issues, but I couldn't get anything solid. The manual told me nothing and I have tried almost everything I can think of. I've tried 3 different CPUs, 2 GPUs and 2 different sticks of RAM 1 4GB Adata stick and a 2GB Unbranded stick. They're double sided and I was reading in the manual how the board doesn't work with ram sticks that are made of 256Mb chips or less and I know that means Megabits but 4GB/16 is 256MB (Megabytes) so I wonder if that might be a problem.
Another issue is that it might just be the speed but im not sure. I don't know the speed of the 2GB stick and the 4GB one is 1600MHz but my board only supports 800/1066/1333(O.C). It's my only DDR3 ram I have so I just hoped the bios would just underclock it, but I guess that's probably not happening.
The parts it has in it right now are all known working except for the ram.
CPU: Core 2 Duo e7300
GPU: AMD FirePro v3900
Motherboard: ASUS P5G41T-M 2
RAM: 4GB Adata AX3U1600C4G11-SD
I don't want to have to buy the only 4GB ram stick that's on the Supported Vendor part of the manual because it's like $40 per module and I don't want to really spend that kind of money on this build. (If I did I would just buy the other motherboard I actually want with DDR2) I will if I have to, but I want to try anything else first.
I haven't tried:
Both of the sticks at the same time.
A different power supply.
Plugging HDMI into the motherboard.
Unplugging the hard drive (idk why that would change anything, but I figured I'd list it anyways).
Using a SO-DIMM to DIMM adapter with slower ram I have from a laptop, but I did order 2 of those adapters to try just in case, but they won't come for weeks.
I can't really think of anything else, so I'll just end it here ig. Hopefully someone can help me out.
I haven't tried:
