Asus p8h77-i heat sink replacement
caremal5
146
So basically, I didn't set my heat sink properly in the first place and now need to buy a new one. Will the noctua NH-L9i be a good replacement or can somebody recommend something that's better?
Hi, I've just noticed a problem with connecting the nh-l12 to my motherboard. To the best of my knowledge the motherboard only has one fan connector on it, is there any way around this issue at all?
right, well I've just tried putting the noctua nh-l12 inside my pc and found out that it's too wide so if anyone could find me a tall heatsink that'll actually fit it would be greatly appreciated.
