Asus P8P67-M Pro won't post after CPU heat sink replacement.
cobra4014
33
Hello, I got a few fans and the cooler master GeminII 564 for my i5 build. After installing with MX-4 thermal paste and extreme care, I have rewired everything back and had it ready to go. Mobo's red LED comes on and CPU, case fans, Graphics card and psu spin up, but theres no 'beep' for the post. The Red Led is for 'DRAM', and that stays on constantly. I'm not sure what's causing it, but I'm panicking because it was running fine before adding these fans. Please help me!!!
🙁. I tried all of that, to no avail. I reseated and reapplied the CPU and thermal paste, reset the CMOS, and cleaned the RAM slots. Is it the memory, PSU, CPU, or mobo? This really sucks.
Yeah switched them all four ways, cleaned RAM and sockets, and rewired everything. Same result. Is there anything else I can do that you can think of?
There's a sort of almost fiberglass padding on the feet (that press into the mobo) and the back (That presses the case). They're not meant to come off, but I'll add some washers if I can. Will report back.
Nope, no dice 🙁 I'm at a loss right now. The only difference I got is that it dosent reboot once and then idle, it boots and idles (before POST). Should I call for the RMA or am I screwed?
