ASUS P8P67 Pro B3 problem after BIOS update
Logpiri2
12
Hi,
I used EZ flash to update my BIOS to "v 3602".
After that it said that BIOS was updated successfully and the system was going to reset, so I clicked OK and nothing happened.
After some minutes I manually reset system and now when I start the computer I can't see anything in my monitor.
In particular when I first start the computer it just reboots itself for once and then it stays running but I can't see anything.
Maybe the BIOS is dead.
Is there a way to recover it? Maybe using a USB BIOS recovery to put in the first USB connector of my board?
Here is the ASUS page: https://www.asus.com/Motherboards/P8P67_PRO/
How can I do that?
Please help me, I need to enter my OS for work and I hope I don't need to replace my motherboard.
Thanks
The crashfree bios should start on its own (if I recall). This happened to me with a p6x58d premium board. Try setting up a usb flash drive and boot from it.It has to be formatted as fat-32 (not ntsf). Have the bios you want to install on it. You will have to rename the bios file to the correct name. The crashfree program will tell you the name it's looking for when you try to use the bios file to flash the bios.
I would also try re-downloading the bios file. It seems easy for them to get corrupted.
