Question asus P8Z68-V LX memory issues please help
ILoveMyPc
4
hello everyone any help would be great been building computers for 6 years so not new to it but cant get around this issue.
specs:
asus p8z68-v lx mobo
intel core i7 3770
cooler master evo hyer 212
memory is xms 1600
1tb sata hard disk
so as you can see by the title i have memory issues i can run 2 sticks which isn't much good lol tried all 4 nothing boots turns off turns on no graphics memory is TR3x6g1600c9 this is 3 x 2gb i have four sticks of these i understand that not all four sticks will work as the mobo states in memory support it will support 3 x 2gb but don't i can only get the two first sticks to work i have updated bios took out battery changed battery etc any ideas
ILoveMyPc
4
Are you on the latest BIOS for your motherboard? You might want to see if all 4 of the sticks have the same make and model, if they're all Corsair XMS sticks of ram.
all of them are xms3 all with the same part number also the same frequency in mhz all the same version and volts
also i had to update to the newest bios for it to run the i7 3770 as this was at a later bios update
sooo therefore i am at a loose end any 2 sticks of ram work in slot 1 and 2
