ASUS P9X79 LE with a i7-4820K - No Post, no display, no beeps, nothing - Just a red CPU LED
analog999
New build.
Getting a red cpu led on a asus P9x79 LE with a i7-4820k. Everything powers up but never progresses to a display, and according to the manual the red cpu led means it stops there because there is a problem.
I'm assuming it's the bios, on a sticker on the MB, the last four digits of the sticker are 3501, which appears to be a BIOS rev number from:
http://vip.asus.com/forum/topic.aspx?elitepost=0&SLanguage=en-us&board_id=1&model=P9X79%20LE&page_size=20&page=1&count=23
According to ASUS, I need bios 4210. So OK, that might be the problem.
But how do I update the BIOS when I can't even see anything on the screen? Tried two known good graphics cards.
Also... Checked cables. Reseated the CPU multiple times. Very careful about static. I've done plenty of other builds and never had an issue. First time with ASUS. Even tried pulling the CPU to see if it would post with no CPU. Nope, won't even turn on without a CPU.
Am I supposed to still get some video if it's just a BIOS version problem?
Please help! Thanks in advance
Ok so here are the steps
1.on another PC goto the ASUS webstie and download the latest bios for the board.
2.insert the USB stick into the slot Marked USB BIOS FLASHBACK or the white one and find the button located on your board or again on the IO Labelled USB BIOS FLASHBACK.
3.Insert the USB and press the button and it flashes your bios.
this works as well if you accidentally brick your motherboard bios and need to reflash it. just do the steps listed here and it will work. BTW your mainboard needs to be connected to the 24pin and 8 pin power i believe for it to work. if your PC is built then its just fine.
EDIT:NAME THE BIOS FILE P9X79LE.CAP and the USB has to be formatted to FAT16 or FAT32. to do this right click the USb in...
Well, there is a USB on case panel that has a white border around it and it says "USB BIOS Flashback" so I would say yes. But the physical port color inside the port is black, just for other's reference.
I'd like to know why the hell this information isn't easily accessible on the ASUS website, and certainly would love to know why it isn't included in the manual.
EDIT:NAME THE BIOS FILE P9X79LE.CAP and the USB has to be formatted to FAT16 or FAT32. to do this right click the USb in the computer tab and click format and select file type of FAT16 or FAT32. Hold the FLASHBACK buton for 3 Seconds until it starts flashing ( if it has an LED) then leave it until the led GOES OUT AND VOILA
That was it, thank you, thank you thank you! Just an FYI for people, don't bother turning the computer on, you just have to have the power supply turned on, and then press and hold the flash button on the motherboard. Also, on this rev of the motherboard, 1.01, there is a LED. Thanks again!
Happy to help. Remember to pick an answer and close the thread :)
I was able to flash mine (not sure if successful) but my pc still wont display video or beep (no RAM)...
Either the mobo is faulty or the BIOS is not flashed correctly. I'm hoping it's the latter. Any suggestions at this point?
I had same problem with asus sabertooth mobo. It's problem with the bios.either its corrupted or fried. but all is not lost, a new bios chip can be got for £10 so try it
my sabertooth came with no bios chip, the red light was on next to the cpu,all the fans were spinning even the graphics card was working . But I had no feed to the monitor?? funny. Now at that time I didnt realize that the bios chip was missing from the board, after a closer look i then realized what the culprit was. I purchased an upto date bios chip from ebay for £10 brand new complete with most upto date bios version for my board
Anybody? I really want to get this pc up and running
