Im trying to get any advice on this problem and to see if anyone has this exact combo.
I bought the R9-295x2 specifically for 4k. I settled on the ASUS PB287 4k display.
Well I just got it today and no matter which of the 4 mini DP port I use on my Radeon the monitor says " No display port signal". I've tried a mini DP to DP cable, Standard DP cable with mini DP adapter, I even went out and bought gold plated DP cables to see if that was the problem. The monitor will still not recieve a signal. I tested the Display on my Xbox one through HDMI and it works just fine. So i went and bought a mini DP to HDMI cable...will not work in DP or HDMI with that.
ASUS Tech support had no clue and said they had not recived any issues with mini DP. I called XFX just to cover my bases and they said they've had no issues with the R9-295x2 connecting to other 4k monitors. They admitted however they had not tested that card with this monitor.
Also when I connected through xbox I was sure to set the monitor to DP 1.2 in the settings hoping that would fix the " no displayport signal" problem....no luck.
So before I RMA this thing I was hoping an expert or mabey somone whos had a similar problem might see somthing I've not tried yet.
Sorry for the length of this, I figured I'd give as much info up front as possible.
Thanks in advance
Thanks in advance
