As the title states, my wifi card antennas broke and I can no longer attacted them. So I was wondering is there a way to get a replacement antenna? Or do I have to repurchase the whole card again?
If the metal on the card broke, then you need a new card. If the coax is detached from the metal, then you can buy a replacement antenna.The thing I highlighted below is broken. Wifi is still working but too unstable to stream.
If that little button connector is broken you need new card.As the title states, my wifi card antennas broke and I can no longer attacted them. So I was wondering is there a way to get a replacement antenna? Or do I have to repurchase the whole card again?
Would any antenna work? Or is there a specific one you would recommend.If the metal on the card broke, then you need a new card. If the coax is detached from the metal, then you can buy a replacement antenna.
AliExpress says they have the original -- https://www.aliexpress.com/item/4000219207979.htmlWould any antenna work? Or is there a specific one you would recommend.
