Asus PCE-AC68 Driver Installation [HELP]
TyJey_
Commendable
Nov 27, 2016
Can you install the driver of this wireless adapter using the CD that comes with it or the drivers of this adapter which you can find in asus website?
Yes you can use either, the website's drivers just might be a bit newer.
I'm going to buy sooner or later so I can use the drivers that is in the asus website? Or I need to use the CD that comes with the adapter or I can use either of them?
