Asus Poseidon 1080 ti with water cooling PLEASE HELP!
Indivision
135
Guys I am getting Asus Poseidon 1080 ti and I want to be with water cooling. where to find proper cooling for it and some instructions I was looking for something but im not sure that he videos for other cards will help me with put on Poseidon not sure if its the same please help :)!
Regards SamuilB
you will need a pump, radiator, fittings, tubing and reservoir to liquid cool this card. it will cost you 200-300USD depending on the parts selection.
it's basically takes to build a custom loop to liquid cool this card.
Another option would be using an expandable AIO like Swiftech H240 X2. this way you also add the CPU to liquid cooling.
As a side note, this probably not the most cost/performance effective way. if you want to liquid cool the GPU, just get much cheaper 1080Ti that is based on reference design and get an EK fluid gaming kit. depending on your case and room temperature, you might want to add another radiator.
Instructions on how to do that can be found on youtube - check out JayzTwoCents channel. he have plenty of...
Instructions on how to do that can be found on youtube - check out JayzTwoCents channel. he have plenty of videos on liquid cooling including step by step planning and installation.
